2007 Cadillac STS P0496
mredmond
Postby mredmond » Tue Feb 26, 2013 11:36 am
My engine light came on with a code P0496 which is EVAP can anyone tell me where this is located on the engine and do I need to replace it. Thanks
Re: Catillac 07 STS
Postby kev2 » Tue Feb 26, 2013 2:58 pm
knowing which engine would help us help you -
the purge valve located on top of engine, under the 'sight shield' - may stick open r closed... there was a special coverage policy- not sure of years involved- if you determine yours is bad ask dealer if your vehicle is covered, 3.6L?.
Let us knoe which eng and someone will help localize the component
mredmond
Re: Catillac 07 STS P0496
Postby mredmond » Wed Feb 27, 2013 5:52 am
Sorry about that I believe I have a 3.6L V- engine found out that their are two of them one in the front as you were saying and one in the back, how can I tell which one is bad, and the one in the front is it easy to get to under the shield and the back one where would it be located and is it it easy to get too Thanks
Postby kev2 » Wed Feb 27, 2013 10:25 am
purge valve is in front on eng....vent valve is in back tank/canister area -
remove sight shield- R/S engine - above center coil - will have vacuum lines to help ID...
without a scanner I cant think of an easy DIYer check of the valve operation.. Is enging running rough?
mredmond
Postby mredmond » Sat Mar 02, 2013 10:23 pm
Yes it does run a little rough in the morning is this something that I can do or would you recommend taking it to a machanic
Postby kev2 » Sun Mar 03, 2013 7:46 am
you can change it- no major job - BUT ewplacing the component is not always the corrective action. could be more than a failed component.
Cadi is likely one of the most advanced of all vehicles on par wirh Benz in uniquie systems and 'logoc'.... recomend you find a shop specializing in cadi - before a major this would be a time to select.
mredmond
Postby mredmond » Mon Jan 06, 2014 4:58 am
I finally put my 07 Cad STS in the shop for the vent solenoid can anyone tell me if the solenoid is by the gas tank or do you have to take the gas tank down to get to it because I was told you have to take it down to get to the part and now that its been fixed I'm having a rough idle and you know how when you start your car up your engine light comes on then it goes out well mine doesn't come on all and go back out, is it possible that the mechanic perminatly turned my engine light out because he didn't fix the problem.
Postby kev2 » Mon Jan 06, 2014 9:37 am
I doubt an AUTHORIZED Cadillac dealer would do what you suspect... BUT a easy free way to check would be take advantage of the Free code scans at Autozone et al part stores... FREE if there is an issue wuth the OBD system it will report - a code.
mredmond
Re: 2007 Cadillac STS P0021
Postby mredmond » Fri Jan 24, 2014 8:16 pm
I just got my car fixed for the code P0496 EVAP, after I got that fixed my engine light comes back on I went to AutoZone low and be hold I get another code P0021 saying (intake camshaft position system performance) can anyone tell me what this is what part do I get and where is it located can I put this part on or is this to complicated. I have a Cad sts 07 6 cycl
Re: 2007 Cadillac STS P0496
Postby kev2 » Sat Jan 25, 2014 8:37 am
mredmond
Postby mredmond » Wed Feb 26, 2014 5:10 am
Hi Folks, I got a engine light code P0021 and I ran the live date report on my scanner, can anyone tell me what all of this information means and does this information tell me what the problem is
Fuel System 1
n/a
Fuel System 2
n/a
Load Value
Bank 1- Sensor 2
STFT-99%
Bank 2- Sensor 2
02S 445V
Bank 2 - Sensor 2
STFT - 99%
MAF Air Flow Rate
0.0
Throttle Position
15.6%
Bank- Sensor 2
02s Output 445v
Veh Speed
0.0
Ignition advance
5.0 des
Intake air temp
104. F
STFT Bank 2
0.0%
LTFT Bank 1
1.5%
Coolant Temp
167
STFT bANK 1
0.0%
LTFT bANK 1
0.7%
Please help if anyone can break this down and tell me what the problem is thank You
Postby kev2 » Wed Feb 26, 2014 9:05 am
all that info will be explained im the scan tool manual, or visit the manufactures
web site - often different manufacturers use different 'names' for different information...
p0021 is an issue with VCT - wiring? solenoid? actuator?
http://www.obd-codes.com/p0021
