Toyota Corolla 2005 OBD P0441 & P0455
Please use the manufacturer specific forums above this where appropriate
jcanales
Postby jcanales » Sun Dec 20, 2009 3:13 pm
I have a 2005 Toyota that I just took in to Pep Boys for a OBD screening exam and they informed me that it had two codes P0441 & P0455. Now my concern is, How much will this cost me?... Does anyone know...If so please respond.
MIL_magician
Re: Toyota Corolla 2005 OBD P0441 & P0455
Postby MIL_magician » Sun Dec 20, 2009 4:11 pm
There was a bad batch of main engine computers on that model that would incorrectly control what is called a "purge valve" on the fuel vapor system. If the car has less than 80,000 miles, it's covered by a federal warranty through the Toyota dealer, and it's free.
T.S.B. # EGO41-07. As long as the valve itself is working correctly (step #1), the computer gets replaced (step #2). I hope it's got less than 80K, or else this fix gets really pricey out of pocket, provided it's not a faulty gas cap or an intermittent issue with the vapor lines and components.
jim47
Postby jim47 » Mon Dec 21, 2009 1:34 pm
You have a (Large) leak in your evap system. Either you got this by age, or negligence of Pepboys crew. It's easy to stick a screw driver through the evap hosline and tell you you need a new one. I worked for this Company of negligent ASE mechanics and have personally known that they cant even put a Brake Star-adjuster on right.
Common negligence is why I personally quit Pepboys chain.
Hicksville NY Old country road
As an employee, I wanted to have a wheel alignment done, It took them "three" days to perfect a wheel alignment which takes 1 hr anywhere else.
jim47
Postby jim47 » Mon Dec 21, 2009 1:36 pm
MIL_magician wrote:There was a bad batch of main engine computers on that model that would incorrectly control what is called a "purge valve" on the fuel vapor system. If the car has less than 80,000 miles, it's covered by a federal warranty through the Toyota dealer, and it's free.
This person obviously has no clue about Pepboys and it's employee's.
MIL_magician
Postby MIL_magician » Mon Dec 21, 2009 7:24 pm
Yes, I'm aware of the skill level and competence of that businesses employees, both current and former....
http://ww2.justanswer.com/uploads/skyvi ... 45_441.pdf
mullo666
Postby mullo666 » Tue May 04, 2010 2:48 pm
Ok so back in april I just had to get my ecm replaced due to default. Well now i have four codes reading two p0441 and two 0445. Is it possible this is a default of the ecm again?
Since nothing is wrong with car and i noticed post from mil_magican:
jeff compton
Contact:
Postby jeff compton » Tue May 04, 2010 9:11 pm
Im skeptical that is an ecm causing those codes! especially on that make and model! It's more likely to be the valves plugged from a deteriorated cannister!
mikekris
Postby mikekris » Mon Jun 13, 2011 10:33 pm
the price always depends on the auto mechanic who will going to check and repair your car. maybe if i tell you the price, you might expect that the auto mechanic who will going to fix your car might give a price that is higher to the price that i am thinking. so my advise is to do the repair by yourself. find a site where you can find auto repair manuals that will help you to fix it by yourself for you to save money.
hdlc
Postby hdlc » Sat Nov 17, 2012 11:01 am
Hey mullo666 - What was the problem that you found out I had the similar issue now ? How did you got it fixed and how much does it cost to you ?
Postby kev2 » Sat Nov 17, 2012 11:15 am
hdlc start a new topic - year make model eng etc, tell us issue your having recient work done anything to help solve the problem.
Return to “General Car Repair Forum”
