2007 PT Cruiser P0441
Also including Plymouth and Eagle
Willydee
Postby Willydee » Thu Jun 15, 2017 6:04 pm
P0441
cj1
Re: 2007 PT Cruiser P0441
Postby cj1 » Thu Jun 15, 2017 9:26 pm
You'll have to do some testing to pinpoint problem. See trouble codes this forum for causes/solutions.
Bad vacuum switch
Broken or damaged EVAP line or canister
Open in PCM purge command circuit
Open or short in Voltage feed circuit to Purge Solenoid
Faulty purge solenoid
Restriction in EVAP solenoid, line or canister
Corrosion or resistance in purge connector
Bad PCM Pos
Return to “Dodge, Chrysler, Jeep, Ram”
