1996 f150 multiple codes
Also includes Mercury
Randy Barras
Vehicle: Ford f150 4.9l i6
Postby Randy Barras » Wed Jun 14, 2017 9:25 am
Hi guys,
As stated above, I have a 96 f150 with the straight 6 and the check engine light is on. It has generated 7 codes and they are as follows; PO153, 155, 171, 174, 401, P1405, P1151. Dont know if it is related but the needle only gets to the "N" on the temp gauge even after a brand new thermostat. Also replaced the PCV valve.
I am only a DYIer with a fair amount of mechanical skills and need some advice on where to begin.
Thanks,
Randy
Re: 1996 f150 multiple codes
Postby kev2 » Thu Jun 15, 2017 6:12 am
Randy Barras
Postby Randy Barras » Wed Jun 21, 2017 9:51 am
Thanks Kev2,
EGR passed test.
Is it possible that engine operating (low) temperature is related to this or a separate issue?
Postby kev2 » Wed Jun 21, 2017 10:16 am
there is the gauge and the ECT the PCM sees not the same circuit, there are 2 sensors.
Ideally with a scanner look at the PCM for the ECT it is seeing, not the same as gauge.
Return to “Ford, Lincoln”
