Code p0480, 2003 monte carlo
Dankdank
Vehicle: 2003 monte carlo ss
Postby Dankdank » Thu May 18, 2017 1:31 pm
I have a 2003 monte carlo the engine light on I got a code p0480 reading I changed the temperature sensor it went off then came back on the fans do work it comes on when idleing when temp about 185-190 car does not over heat went back to auto zone same code comes up
Re: Code p0480
Postby kev2 » Thu May 18, 2017 2:04 pm
Why did you change temp sensor?
This is a fan relay code - relay #1 circuit issue.
underhood fuses - fan control #1, 25amp, then ck fan cont #1 relay,
There are 2 boxes underhood top and "BOTTOM" owners manual will help if you have trouble. Or ask us.
AUTOZONE sells parts.
Dankdank
Re: Code p0480, 2003 monte carlo
Postby Dankdank » Fri May 19, 2017 10:43 am
I changed relay still the same code reading
Postby kev2 » Sun May 21, 2017 8:58 am
did you check fuses ?
CAn you use a DVOM and wiring dia?
Dankdank
Postby Dankdank » Sun May 21, 2017 12:04 pm
Yes I check fuses all good what's a dvom and wiring diagram?
Postby kev2 » Sun May 21, 2017 3:02 pm
Code indicates the PCM is not seeing correct voltage on green wire...
Confirm that the 2 wires I colored have 12v kOEO.
OR swap relays 1 wit relay 2 see if code changes....
Let us know if there is a remote starter or aftermarket alarm...
