2004 Sebring OBDII error - Mode $06 - On-Board Monitoring Fail
Also including Plymouth and Eagle
conviso
Vehicle: Chrsler Sebring Convert 2004
Postby conviso » Wed May 17, 2017 7:37 pm
I have a MIL light on, it reported the O2 sensor so I replaced the upstream (voltage was 0 on bank 1 sensor 2)
Now the check engine light has come on again, with the same O2 sensor low voltage and I do not know what
Mode $06 - On-Board Monitoring -
Component Id $00 - TID $72 - Manufacturer Defined - 0 - 40 - N/A - Fail
means
See attached full report
Thanks for any help
Diagnostic Report 2017-05-10.pdf
(144.87 KiB) Downloaded 13 times
Re: OBDII error - Mode $06 - On-Board Monitoring Fail
Postby kev2 » Thu May 18, 2017 7:36 am
convertible ? - which engine as there is a mental flag as it may be Mitsubishi ...
p0137 is B1S2 that is POST cat sensor "downstream".
I will check BUT I think $72 is EVAP and I see the monitor not complete - there is a PENDING file for codes can you check it?
As for looking at codes live data will help -
look at the voltages for ALL o2 sensors
GTG
conviso
Postby conviso » Thu May 18, 2017 8:24 am
yes, it is a 6cyl 2.7liter convertible
I am not sure if it is a Mitsubishi
I will pull live data - I do not know how to find the pending code - I thought it was the same
if p0137 is downstream that must be the issue?
Postby kev2 » Thu May 18, 2017 8:39 am
need to know what the voltage is -
SWAG a wiring issue at sensor.
To set a code Evap system requires several tests and there are conditions to be meet -some as unrelated to EVAP as fuel level, ECT, Speed and other issues.
Ask the manufacturer of scanner about pending codes they are all different.
Postby kev2 » Thu May 18, 2017 8:43 am
I just read the report again and PENDING is reported and none other than P0137.
Lets work that (P0137) and recheck.
conviso
Postby conviso » Mon May 22, 2017 6:25 pm
Thanks for the help _ just replace both the upstream and now the downstream o2 sensor and still have the P0137 error
See updated OBD log
Diagnostic Report 2017-05-22.pdf
(144.81 KiB) Downloaded 7 times
Re: 2004 Sebring OBDII error - Mode $06 - On-Board Monitoring Fail
Postby kev2 » Tue May 23, 2017 8:14 am
Why did you change the sensor ?
need to know what the voltage is - then try to manipulate it rich (hugher viltage) to confirm wiring is ok.
conviso
Postby conviso » Tue May 23, 2017 8:46 am
I thought the P0137 was an upstream O2 sensor error -
how do I manipulate it rich?
Doesn't the report show the Mode 1 powertrain data show the 02 bank2 sensor 1 voltage .5 and sensor 2 as .94 volts? what is the range?
Thank you so much for your help
Postby kev2 » Tue May 23, 2017 10:04 am
Sorry no time today....
conviso
Postby conviso » Tue May 23, 2017 1:56 pm
here is an updated OBDII report
Diagnostic Report 2017-05-23a.pdf
(30.47 KiB) Downloaded 5 times
Postby kev2 » Wed May 24, 2017 8:11 am
confusion over which engine - post 8th character of vin# R or T ?
•2.7L V6 VIN R Automatic
•2.7L V6 VIN R Standard
•2.7L V6 VIN R U/K
•2.7L V6 VIN T Automatic
•2.7L V6 VIN T Standard
•2.7L V6 VIN T U/K
conviso
Postby conviso » Wed May 24, 2017 8:30 am
It is an R w automatic Transmission - 2,7L V6 Chrysler Sebring Convertible 2004
Postby kev2 » Wed May 24, 2017 11:50 am
A scanner will be needed to see what voltage the PCM is receiving from the sensor...
Trouble Code: P0137 (2.7L V6 VIN R Auto)
O2 (B1 S2) Sensor Circuit Low
Code Conditions:
Engine running; battery voltage over 10.9v; O2 heater temperature below 484ºF (251C) or ECT above 170F from previous key off. The PCM detected the O2 Sensor signal voltage was less than 2.402v for 9 seconds
Possible Causes:
•O2 return circuit is shorted to ground
•O2 signal circuit is shorted to ground, or to O2 return circuit, or O2 heater ground circuit
•O2 Sensor has failed
•PCM has failed
conviso
Postby conviso » Tue May 30, 2017 4:38 pm
Thanks so much for the help
I have replaced the upstream and downstream O2 sensor
in Mode 6 - I have a fail on
Component Id $00
Reads 0 - should be 40 min
Do you know what that is measuring
Thanks again for all the help
Diagnostic Report 2017-05-30.pdf
(30.38 KiB) Downloaded 2 times
atip
Postby atip » Wed May 31, 2017 3:36 pm
Hello guys. I been watching this tread.
CID - Component id
TID - Test id
It's failing test $72 - could not find out what test is it.
what is strange as one time it passes...
mode 6
Component Id $7F TID $72 - Manufacturer Defined 65535 65535 N/A Pass
other time failing...
mode 6
Component Id $00 TID $72 - Manufacturer Defined 0 40 N/A Fail
difference between them are cid values $7f and $00, then values, "value, minimum, maximum"
value, minimum, maximum and result
65535, 65535 , N/A, Pass
0, 40 , N/A, Fail
then
SAE 0x15 O2 voltage (Bank 1, Sensor 2) 1.27 V
SAE 0x19 O2 voltage (Bank 2, Sensor 2) 1.27 V
why is failing just bank 2 as bank 1 has same values also, confusing.....
conviso
Postby conviso » Wed May 31, 2017 8:46 pm
Thanks so much Atip
I notice that as well, sometimes it passes, other times it fails
I have no idea what $72 is
I was wondering is bank 1 the upstream and bank 2 the downstream O2 sensor -or how to tell witch is witch
what is sensor 1 verse sensor 2? (Is that some systems have two sensors? in this case there is only one o2 sensor per bank?
atip
Postby atip » Thu Jun 01, 2017 2:32 pm
Return to “Dodge, Chrysler, Jeep, Ram”
