P0487 EGR Throttle position Control Circuit 2007 Mitsubishi Outlander
Post Reply
Revbot
Vehicle: Mitsubishi Outlander 2007 2.0d
Post by Revbot » Tue May 16, 2017 1:01 pm
Hi all,
I'm new to this forum and new to Mitsubishi. I have the P0487 code constantly. I have a 2007 Mitsubishi Outlander 2.0 DiD. The car runs fine but does splutter on low revs (say when in second gear moving slowly in traffic at about 1500 to 2000 revs), I read an article on here about checking the Throttle Control Valve. I have 4 pins, with ignition on, the plug to the TCV had a 12v, a 3.15v, another 12v and a ground. Does this sound right? Any help or advice would be greatly appreciated. Thanks in advance.
cj1
Re: P0487 EGR Throttle position Control Circuit 2007 Mitsubishi Outlander
Post by cj1 » Tue May 16, 2017 4:04 pm
P0487 EGR valve/circuit problem.
Don't have a schematic for the circuit so can't advise on voltage readings however has the EGR valve/openings been cleaned?
Revbot
Post by Revbot » Tue May 16, 2017 5:56 pm
Hi, thanks for the reply. I've got some egr cleaner but not cleaned it out yet. I will try to do it this weekend, & post the results.
Post Reply
