2006 Chevy Trailblazer EXT LS-P0442 code
AmyJo
Vehicle: 2006 Chevy Trailblazer EXT LS
Postby AmyJo » Tue May 16, 2017 5:19 am
Check engine light comes on when my gas tank is close to 1/4 tank. Code P0442 code comes up under diagnostics. Gas cap has been checked and is ok. Any ideas what could cause this, or what to try replacing first? :roll:
Re: 2006 Chevy Trailblazer EXT LS-P0442 code
Postby kev2 » Tue May 16, 2017 6:59 am
The EVAP* tests do run with regard to fuel level.
Some basic info -
https://www.obd-codes.com/p0442
*these are the so called 'gas cap' codes as that is 1st thing to check.
AmyJo
Postby AmyJo » Tue May 16, 2017 7:31 am
Thank you! I am guessing that as long as my gas tank stays above the 1/4 tank my EVAP tests will not properly detect this issue...I hate seeing the light but don't want to ignore the issue. Gas cap is good..already checked. I will have to see if I can have the smoke test done to hopefully find the issue quicker.
Postby kev2 » Tue May 16, 2017 7:38 am
The evap system is not a critical issue - Yes you can plan on when to repair.
A common code and smoke testing is easiest and very common. Good luck.
Be advised erasing codes erases a lot of info not just the code.
AmyJo
Postby AmyJo » Tue May 16, 2017 7:51 am
Thanks for the information!
