P0001 code on 2001 Buick LaSabre
raylat
Vehicle: 2001 buick lasabre
Postby raylat » Mon Apr 17, 2017 1:49 pm
Can someone tell me where the fuel volume regulator is located. I can't find it in the service manual. I have a 2001 Buick LaSabre.
Re: P0001 code
Postby kev2 » Mon Apr 17, 2017 2:13 pm
Confirm 2001 Buick LeSabre 3.8L - reason is I do not see a p0001 on my quick check.
raylat
Re: P0001 code on 2001 Buick LaSabre
Postby raylat » Mon Apr 17, 2017 3:31 pm
That is correct 3-8L Fuel Volume regulator circuit open.
Postby kev2 » Mon Apr 17, 2017 4:41 pm
I have checked several resources and do not see a p0001 code for this model & engine.
Hopefully a colleague will respond.
Sorry Only suggestion till then is maybe try another scanner -
cj1
Postby cj1 » Mon Apr 17, 2017 9:11 pm
You should have a fuel pressure regulator on the fuel rail. Can you id it in the service manual?
It operates on vacuum, no electrical circuit.
As for the P0001, i believe it is associated with diesel or direct injection engines.
Users browsing this forum: Ahrefs [Bot] and 1 guest
