2006 Nissan Frontier with P0463 code.
Also including Lada, Dacia
Amoham
Vehicle: Nissan Frontier
Postby Amoham » Mon Mar 20, 2017 11:15 am
Just want to know if anyone has the same problem and what was the fixed.I have a Nissan Frontier 2006 with the check engine light on. The code is P0463, fuel level sensor "A" Circuit high. Failed emission test.
Re: 2006 Nissan Frontier with P0463 code.
Postby kev2 » Mon Mar 20, 2017 3:29 pm
I have seen this when fuel pumps are changed or some other work in the tank area - a wire is swapped pinched and voltage shorts to the signal wire...
atip
Postby atip » Fri Mar 24, 2017 3:33 pm
This code isn't related to emission failer.
Have you plugged EOBD or OBD2, if EOBD then needs OBD2 as EOBD will show some of general codes but not all of them.
Emmision failer could be:
-exhaust system leak
-intake system leak
-lack of fuel pressure
-Air Flow Sensor
-EGR valve
-Engine Temerature Sensor
-lack of compression
-ignition fault
-Oxygen Sensor
-EVAP fault
That list of main problems.
atip
Postby atip » Fri Mar 24, 2017 3:36 pm
Is it a diesel or petrol engine?
Return to “Nissan, Infiniti, Renault”
