2008 Acura TL 3.2 p0108 and p2279
Biggjohn
Vehicle: 2008 Acura TL 3.2
Postby Biggjohn » Sat Mar 18, 2017 1:28 pm
I replace all my o2 sensors and map sensor and air intake hose and cleaned out my throttle body no I'm getting off codes of p0108 and p2279 I have an 2098 Acura TL 3.2 any help would be great thx
Re: 2008 Acura TL 3.2
Postby kev2 » Sat Mar 18, 2017 1:46 pm
why did you replace all o2 sensors, map sensor and air intake hose and clean throttle body ?
Anyway those codes P0108 and p2297 suggest a vacuum leak, try the old school carb spray trick to locate vac leak...
https://www.youtube.com/watch?v=mYa8rcHeN3A
Biggjohn
Re: 2008 Acura TL 3.2 p0108 and p2279
Postby Biggjohn » Sat Mar 18, 2017 4:39 pm
The car has about 150,000 miles and the o2's needed to be replaced the air intake hose was broken and I cleaned inside the throttle body to remove all the gunk build up as far as the map sensor I replaced it because it broke I don't know that "old school trick"
Postby kev2 » Sun Mar 19, 2017 6:43 am
> Did you look at the attached video?
> you replaced MAP - might want to check vac source to MAP sensor.
ranntmuth
Vehicle: 2005 honda accord ex 2.4l
Re: 2005 accord ex 2.4l po717 and po718
Postby ranntmuth » Thu Mar 23, 2017 7:52 am
the car has 135000 miles and the wire and voted check ok replace input speed sensor. drive for well same problem come back again. Help what i do wrong...?
Return to “Honda, Acura”
