2003 Chevy Truck wont start sometimes P0342
nahaley
Vehicle: 2004 chevy silverado 5.3lt
Postby nahaley » Sat Mar 18, 2017 8:22 am
Changed camshaft position sensor due to lack of power and black exhaust,after changing everything seemed fine, now after a couple weeks truck wont start sometimes, it will roll but won't start! Any suggestions?
nahaley
Re: Truck wont start sometimes
Postby nahaley » Sat Mar 18, 2017 8:31 am
It is also showing a PO342 code
Postby kev2 » Sat Mar 18, 2017 8:57 am
There are no other codes or issues?
ideally a scanner to check if CMP signal is getting to PCM. Also check freeze frame for a clue.
Maybe check elec connector at CMP, tight corrosion free no bent pins, is there 12v - good ground and producing a signal,
Vehicle should start without CMP maybe on second attempt but start - I suspect there are other codes or issues.
Users browsing this forum: autojoe and 1 guest
