Post subject: Mouse built nest in aircleaner box 2005 Chevy Silverado
Posted: Tue Jul 28, 2009 1:15 pm
I have an '05 Silverado. The check engine light came on. I checked the codes P0171 and P0174. When I opened up the air cleaner box a mouse had chewed up my air cleaner and used the insulation blanket to make a nest. I cleaned up the mess installed a new air filter and re set the codes. After driving around for a day the same codes came back. Any suggestions?
Post subject: Re: Mouse built nest in aircleaner box 2005 Chevy Silverado
Posted: Tue Jul 28, 2009 3:46 pm
I would check the Mass Air Flow meter real good and make sure the elements are clean...Also the intake gaskets are common to leak on these and cause the same codes.
