Check for other evap system leaks with a smoke machine around the fuel and vapor hoses might want to check your vent valve o ring if its cracked that can cause this code
If you are familier with the EVAP hoses, check all of them real good for splits and cracks it being a small leak my be had to find but it can be done without a smoke machine just have to look at all the rubber hoses. VERY common to split on chrysler products.
