It is currently Fri Nov 20, 2009 6:43 pm
 Post subject: Chevy S10 extreme codes P0131, p0137, p0151, p0300
PostPosted: Tue Aug 29, 2006 3:03 am
I have a 2003 Chevy S10 V6 80K miles, that has been slow starting and intermetently been running rough. Just today the check engine light lite up while running rough. Codes P0131, p0137, p0151, p0300 were retrieved from the computer. The funny thing is that if the truck is shut off for a few seconds, it will startup and run fine for a while. Is this possibly a fuel pump/filter issue? The filter was replaced about 5K ago. Since the fuel pump costs about $300, what is the best way to check it out? Any suggestions would be greatly appreciated.
PostPosted: Tue Aug 29, 2006 5:50 am
sounds like a problem with the fuel pressure regulator and or an injector blleding pressure off. You'll need a pressure gauge hooked into the fuel system to verify proper pressure and whether it's bleeding off
Good luck and keep us postted
Jeff
PostPosted: Tue Sep 05, 2006 5:42 pm
Thanks for your suggestion. Hooked up a fuel pressure gauge. The pressure was very irregular and dropped immediately when the car was shut off. Someone recomended a fuel pump. After replacing the pump runs great. Thanks again for your input.
PostPosted: Wed Sep 06, 2006 11:01 am
it's pretty common failure
cheers
jeff
Users browsing this forum: No registered users and 5 guests
