It is currently Fri Nov 20, 2009 11:07 pm
 Post subject: P0500 [Speed Sensor test
PostPosted: Wed May 17, 2006 12:07 pm
Hello, My 1999 Taurus has set a P0500 code in memory.
The Speedometer is inoperative and the Transmission is erratic.
I need the test sequence and values for the speed sensor.
The car build date is: 02/99, Vin #is 1FAFP53S7XA207592,
TR: X.
PostPosted: Wed May 17, 2006 2:38 pm
can't get you the test sequences but have heard that VSS (vehicle speed sensors) are a common failure item. Possible wiring issues at some connectors as well but I'd inspect the sensor and wiring first, If you have a scan tool that will read the vehicle speed as you're driving then it should be easier to troubleshoot although not mandatory
good luck and keep me postted
Jeff
PostPosted: Mon May 22, 2006 12:00 pm
Jeff,
You were right! I removed and replaced the speed sensor [it didnot turn freely] and all is back to normal.
This vehicle is rust free so I keep it off the road from Dec. to May. I do start it in the winter on occasion to charge the battery etc.
The Speed Sensor is located just above the right bank CAT and is subject to a bit of heat [has a foil heat insulator around it]. My suspicion is that it got too much heat and failed.
Thanks for the recomendation,
Karl
