I have read through all of the previous posts regarding these codes and tried various advice to no avail.
Background: 1999 Honda Accord EX, stock, 125,000 miles, fairly good maintenance, but not perfect. Driving without any noticeable drop off in performance until the event described below.
Just this past Sunday my engine started running really rough and the check engine light started flashing. The OBD II codes are P0300-P0304 and P1399 (P0300- random / multiple misfire, P030x = Cylinder x misfiring, P1399 = Manufactures control Ignition system OR Misfire). Per advice found on this forum, I pulled each of the plugs to see if it was one of the ignition coils, but they all seem to be ok (made the engine run worse when unplugged). The engine runs fine at all RPMs in neutral, but under load it runs like garbage until about 2800 RPM, then suddenly jumps to 3000 and runs fine. When the transmission shifts and the RPMs drop below 3000, it again runs like garbage until it gets up to about 2800 RPM again.
Yesterday I checked the fuel trim numbers (again, per advice on this forum) with the following findings: 1. I/M Status: Catalyst, Evap Sys, O2 Sensor, EGR Sys - Not Ready 2. Short term fuel trim was all over the board, but mostly in the small numbers +/- 5% or so. It seemed to jump to around +20% at the worst of the rumbling, just before jumping to running smoothly again.
Some of my thoughts, based largely on only a rudimentary understanding of how the fuel system works: It is probably getting too little fuel or too little air, so it could be the air cleaner and fuel filter. It seems that it wouldn't be the injector since all the cylinders are misfiring. (However, if one cylinder was misfiring, could it cause the others to misfire?) It could possibly be a bad O2 sensor messing up the computer's calculation of fuel needs.
Additional background info: I was driving in the mountains in WV all weekend, the weather was warm and wet, the car was fairly empty and I wasn't hauling anything, my passenger was being somewhat annoying, and Sam Cooke was on the stereo.
Any help you can provide will be greatly appreciated.
Cheers, Ash
