Hello all,
I am new to this forum but already impressed by what I've read. It's nice to have a community like this. My 2001 VW Jetta has had a history of MAF sensor problems, so I thought for sure my current issue was of that nature. However, I put in a brand new MAF and it ran the same way (so I returned the part and put the old one back in). Anyhow, here are the symptoms, then the error codes.
* The car runs/idles really rough if it's been raining or maybe if there is a lot of moisture in the air.
* While driving down the road I will get little bursts of power like a cylinder is kicking in all of a sudden.
* Usually the problem goes away after high speeds or several miles of travel.
* I have used fuel additive (techron) but it made no difference. I have also used higher grade fuel. No difference.
* As soon as the cold weather came (I live in Maine) the problem stopped. Today was an unseasonably warm 50 degrees and rainy and sure enough, my car ran like crap. (Idles really rough, no power, weird bursts of power)
Here are the results of a scan (I know there are probably a few unrelated problems here; arg!)
6 Faults Found:
17550 - Load Calculation Cross Check: Lower Limit Exceeded
P1142 - 35-10 - - - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4 Misfire Detected
P0304 - 35-00 - -
17574 - Long Term Fuel Trim Additive Air Bank 1: Range 2: System too Rich
P1166 - 35-10 - - - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-10 - - - Intermittent
Any help would be greatly appreciated
