I've got a 1996 Chevy 1500 with 150,000 and I get the following codes: P1406, P0101, P0102. Got a used EGR valve, installed it and got the same codes. Is there any way to test the EGR valve off the engine? Not sure if the used one is any good. Could the MAF codes be caused by a bad EGR valve? Is there anything else I can do before buying a new EGR valve? Thanks Fishfarmer
Post subject: Re: 1996Chevy 1500 P1406, P0101, P0102
Posted: Wed Nov 19, 2008 7:27 pm
Not to ask the stupid question but did you clear the codes before you read them again? Just wondering. I did that at first> Replaced a sensor, checked the code, light was still on, got pissed, cussed alot, took my stupid pill, cleared the code, and the light went out. Good Luck
Posted: Wed Nov 19, 2008 9:31 pm
The egr valve on these have a very high failure rate. Odds are the used one is also bad. If not you also need to check the egr passages for blockage, use are pressure and see if it goes through the ports.
Users browsing this forum: Google Adsense [Bot] and 8 guests
