Can a bad tsp spring a p0300 code???? The car acts funny when on and off the gas...THEN CODE POPS UP AND SOMETHINGS THE LIGHT FLASHES.... any info would be great...
Most of the time if you have a TPS problem you would have a TPS code of some sort. What kind of mazda is it? Don't think a TPS would cause of misfire anyway, a hesitation or stall yes but no misfire. When the light is blinking the PCM is detecting a misfire. At what RPM range does it blink?
its a 99 mazda millenia with the 2.5....its has 152k miles on it and runs great most of time....a two week ago i gave it tune up..... (plugs, wires, cap and rotor)... its has a bad hesitation and the light goes crazy .... then pulls these codes last night p0300,p0120,p0130,p1170...they poped up when i was changing out the tps....thanks
Check the rubber air duct (throttle body to air flow meter) make sure its not split or has any holes on it. If it is split you can wrap it up with tape JUST TO SEE if it runs better. If it does it needs to be replaced.
