It is currently Sat Nov 21, 2009 3:57 am
Post new topic Reply to topic  [ 2 posts ]
 Post subject: P1406 GMC Truck
PostPosted: Thu Mar 09, 2006 12:45 pm
I have a '96 4x4 GMC 350/Auto - STOCK. The OBD is holding a P1406 error code. I would like to know what it is and how to fix it. Any help is greatly appreciated.
Thanks,
Chris
 Post subject: p1406
PostPosted: Thu Mar 09, 2006 4:38 pm
P1406 is an Exhaust Gas Recirculation (EGR) valve position sensor-range performance code
What it means is that the pcm is not seeing the egr valve pintle change positions when it's commanded
Probaly you just require a new one, Some mechanics try cleanning them first but it doesn't always fix them. Can also be a wiring problem to or from the pcm but not as likely. I think GM had a software update that
preventted the new valves from carbonning up. It cycled the valve with the key off, engine off to keep anything form sticking to it as it cooled
Might be worth checking into
Hope this helps
Good luck and keep me postted
Jeff
Users browsing this forum: No registered users and 1 guest
cron
