Post subject: 2000 Camaro V6-P0102 Mass Air Flow (MAF) Circuit Low Input
Posted: Fri Oct 17, 2008 10:43 pm
I have a 2000 Camaro V6 3.8L and has the code P0137 Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2) but does not have any performance issues since I figure that the O2 sensor is more emissions related. Every other day the SES light turns on then turns off but the car runs fine...until today.
It has a decrease in power and has sluggishness and now it also has code P0102 Mass Air Flow (MAF) Circuit Low Input. It comes to a point where the car dies out and I have to restart. When I give it full throttle, it sputters.
The K&N filter is in good condition and the connector to the MAF sensor looks fine (I have a stock intake). There is not cracks on the intake or anything.
I was thinking of removing (and being really gentle) the MAF sensor and cleaning it with brake cleaner but wanted to see if I can get some advice here. Thanks in advance for your help!
Post subject: Re: 2000 Camaro V6-P0102 Mass Air Flow (MAF) Circuit Low Input
Posted: Sat Oct 18, 2008 8:59 am
The first problem is the K&N filter. The oil from the filter will cause nothing but problems for a Mass Air Flow Meter. You can try to clean it first and see what happens.I would stay away from brake cleaner and use Mass Air Flow cleaner instead.
Posted: Sat Oct 18, 2008 12:29 pm
Thanks for the reply.
Well I've had the K&N in the car since the year I bought it new in 2000 so after 8 years, the MAF/K&N hasn't givent me any problems until now.
The K&N has not been re-oiled. I checked the MAF 3 prong connector that connects from the car to the MAF sensor and looked fine. I even cleaned it with electrical cleaner.
Checked inside the MAF housing for anything blocking the passage (where the MAF sit) and inspected the MAF sensor and looked fine.
Should I clean the actual MAF sensor with the electrical cleaner?
Posted: Tue Oct 21, 2008 9:12 am
I cleaned it and the car ran good for like 5 min then it started acting the same. Can the MAF sensor be tested? How do I know it's the MAF sensor or the connector? Thanks!
Users browsing this forum: Google [Bot] and 3 guests
