After purchasing the car, while driving it home, the general conditions for the P0171 occured(loss/no power, knocking, stalled) Purchased a scanner and got the codes, followed the usual steps. The preculiar thing is that the code 0171 and conditions only occur after the vehicle has been run for atleast 15 minutes, parked, then re-driven. The first run off the day, no matter if morning, noon or night always goes smooth. I have also noticed a "ticking" in the top of the engine prior to the "engine malfunction". I have seen posts where the intake gasket may be a culprit and by having the supercharger, would this make the condition worse? There are also times that after an initial hesitation, sputter, misfire....the engine will operate smoothly. One thing that occurred this evening that baffles me.....car left the stoplight normal and crused up to 55mph without hesitation, but when I "put the pedal down" to pass a vehicle, the RPM's went up 1500, the supercharger spooled up, but the car failed to accelerate and acted like it was in a "suspended animation" and did absolutely nothing. After coming to a complete stop on the side of the road, the car once again accelerated fine. No codes and no MIL. Fuel pump now seems to have a whistling noiise too.
