It's probably the fuel pressure solenoid. OHm it and it should be 30-40 Ohms resistance. Red wire should have 12 Volts with Key on engine off. IF not, replace solenoid.
I have a 1999 mitsubishi eclipse spyder turbo with a obd2 code of 1105 i check the fuel pressure solnoid which this car has none my obd2 code reader says it upper alternator failure ,i'm puzzled need some help thank you. Icheck my car book for the location of fuel pressure soilnoid and did not see it near fuel tank under the seat.
Users browsing this forum: No registered users and 7 guests
