We recently bought a 95 Dodge Intrepid for my son and it ran like a dream. Then the check engine light came on and we stopped and notice the radiator had a crack in it. We took it in to get it changed. We forgot to give them the key fob to turn off the car alarm and they accidentally set it off. They disconnected the battery to shut it off. Ever since then the car has ran terrible. It just started running rough at startup. If he turned it off and restarted it, sometimes it seems to run smooth again. Now it just runs terrible and has no power. We took it back in and they changed the O2 sensor, crank shaft sensor, Cam shaft sensor, checked the coil, plugs, and fuel pressure. He said the fuel pressure was a little high. Can anyone help us? The next thing he wants to change is the module and that is around $300. Are we overlooking something? Here are the specs on the car: 1995 Dodge Intrepid, 3.5 V6, R16 tires.
Thanks for your help!!!
