It is currently Sat Nov 21, 2009 1:00 am
 Post subject: Mazda protege model year 1997
PostPosted: Wed Jul 01, 2009 9:55 am
guys , hello to all
i have a mazda protege 1997 same as mazda 323 but the american edition
my car engine goes down on the rpm every time i it any pedal and my check lamp goes on , when i checked with my obd reader says error code number PN1797 after long time searcing its only says that i have P/N Switch Open or Short Circuit which i dont really understand , could you be be kind to tell me exactly what part i need to change because am not a technician and all here cant fix it
thanks alot
tico :oops:
 Post subject: Re: Mazda protege model year 1997
PostPosted: Fri Jul 31, 2009 2:07 pm
p/n switch is a park neutral switch on your tranny....it keeps your car from starting on DRIVE or REVERSE. Don't know how it can affect your engine but is that the only code you have ?
YOu might have a mechanical problem that is not coding but still causing problems.
Let me know !
PostPosted: Sun Aug 02, 2009 12:35 pm
If the "check lamps" light comes on when you hit the pedals, check your taillights. Sounds to me like you may be confusing the "check engine" light with the one you are experiencing. If that is the case, the code you received when you pulled the codes was more than likely a soft code. If this helps put you on the right track, check your lighting harness for a possible short to ground. That may explain the engine RPM dropping. Then again, I may be way off. I base this off of your choice of words while describing your symptoms. Good luck.
