The engine in my 2003 Dodge Ram 1500 5.7L Hemi is rocking bad and not running smoothly. When I pull the error codes off, I get P0113 and P0172. A friend hooked it up on his machine and got a code for random misfiring and said that one cylinder had no compression. Anyone had this problem, or any ideas on what might help? The vehicle has 80,000 miles on it, and I run only mid-grade gasoline.
I am having the same problem with my engine it has happened multiple times , are you running any after market exhaust system ? I normal come across the problem when I run the engine to a higher rpm than 5000 but my friend races his stock hemi more than I do and has never had this problem wondering if you had any luck with finding the problem
