Okay, so I tried to look around under the forum for a similar enough situation but couldn't find anything to post on. So I have decided to start this thread in hopes that someone can please help me keep my sanity, and keep me from being even more broke and carless.
My problem is with my Kia optima 2001 SE 4 cylinder 2.4L. It has had problems up to wahzoo ever since I bought it, but they were far enough apart and just within my budget that i've kept the car. Now, I can't afford a new car, and I have put way too much money into this car to get anything close back out of it, so I would like to try to keep it another 2-3 years if possible. I am having a physical issue that may or may not coordinate with my trouble code. I receive a P0171 code almost every day if not multiple times a day. It didn't start that way, it used to be once a week, now its more frequent (it seems). Also, the code often resets itself which I am not exactly sure what that can mean. Anyhow, that is the code, the physical issue I am having with my car (besides the presence of the lean) is that it often times has little jerks while driivng, and will raise in RPM but not speed, and then eventually jerk to catch up. It doesn't have issues shifting gears, but the jerks are becoming more common. I have replaced the upstream O2 (on the recommendation of a mechanic), it didn't seem to do anything, I also just recently replaced the MAF sensor myself from a wesbite called A1, it was really cheap compared to the kia part, so i am wondering if it was a mistake to order cheaper? I installed it, the car initially is seeming to have the same issues, but I will update in a day or two since I just put it in last night. Last year I also had all the coils and plugs replaced because a coil went bad and ruined them all. So those should all be okay (I would hope). Any other information or help would be so greatly appreciated. please comment if you need more info, I will check daily to update. Thanks so much!
Ken
