It is currently Sat Nov 21, 2009 12:38 am
 Post subject: 04 Explorer 6 cyl. Flex Fuel Error code P0506
PostPosted: Tue Mar 03, 2009 4:10 pm
I know this code is for Idle Control System RPM Lower Than Expected. I need suggestions on ways to fix the problem or what part I need. The check engine light is on and the engine does not have a steady idle sometimes even stalling. Any suggestions?
Thanks :?:
 Post subject: Re: 04 Explorer 6 cyl. Flex Fuel Error code P0506
PostPosted: Tue Mar 03, 2009 8:04 pm
You can start by a simple cleaning of the throttle bore and reset the pcm. If it still does it there maybe a PCM update to help correct this.
PostPosted: Tue Mar 03, 2009 8:47 pm
How would I go about cleaning the throttle bore? I appologize I am a beginner at this.
PostPosted: Wed Mar 04, 2009 9:42 am
Try using a rag with some choke cleaner on it. Be careful if you're gonna spray choke cleaner into the throttle bore as it can get into your tps sensor, etc. and ruin the electronics. So if you're going to do that just be careful. The safest way(although it takes longer) is to use a rag.
Users browsing this forum: No registered users and 4 guests
