I have a 1996 Ford Contour, 4 cylinder DOHC with the following issues. Each of the error codes seems to have a different fix, and I am not sure where to go from here.
• Rough idling
• Sitting several hours in cold weather, all while car is parked not in gear: held gas pedal at 50% - RPM drops from ~5000-6000 down to idle, then engine dies. Took 5+ cranks before it would start again - running dry / no fuel.
• Worse in cold weather. When engine warm, problems almost non-existent
• Fuel pressure WAS 4lbs under min before the pump and regulator were replaced. I do not have a gauge, so I am not sure if that is back up, but the symptoms did not change.
