I have tried having a few places check it including the dealership & it always gets an error communicating. The cigarette lighter gets power, but I did have an aftermarket stereo put in to it. They used a wiring harness instead of splicing the wire so I would hope that would be ok, but there is a connector on the same bundle as the antenna that is not connected to anything. Everything else seems to work as far as the accessory items (lights, turn signals, horn, etc.). I will check the power on pin 16 & let you know about that. If I don't get power there, what should I do. Also, what fuse(s) should I check. I am leary of just pulling them because there is at least one fuse in there that will set the car in to fail safe mode if it gets pulled & the car runs like a dog until the computer gets reset. Did that before & it cost me 80 bucks to have the dealership reset it. Thanks for the help, by the way.
