Ok I got the P0380-B glow plug code fixed there were 2 bad glow plugs. Now I did find a hose clamp lose. And thank you for the tip on reading the articles on P0101-C. Remeber I already changed the MAF sensor. I found a possible cause paragraph / things that could set a P0101-C code in my scan tool that stats, (5 Volts Reference Circuit, Air Filter Element, Barometric Pressure Circuit, Boost Pressure Sensor, Charge Air Cooler, Diaphragm, Engine Control Module, Exhaust Gas Recirculation, Throttle Valve Solenoid, Exhaust Gas Recirculation Valve Solenoid Valve Diaphragm, Exhaust Gas Recirculation Vent Solenoid, Exhaust System, Hoses, Ignition 1 Volt Circuit, Intake Air Temperature Sensor, Low Reference Circuit, Mass Air Flow Sensor, Mass Air Flow Signal Circuit, O-Rings Seal, Secondary Air Injection Induction System, Turbocharger, Unmetered Air, Wiring Harness / Connectors) What dose the B or C after the code mean? I did put a new air filter in that was the frist thing I did. That is a lot of things that can set the MAF code where would I start? Please help Beam
_________________ Auto Repair Any Where If I can't fix it, it ain't broken.
