It is currently Tue May 21, 2013 5:47 am
PostPosted: Sat Aug 25, 2012 3:21 pm
Problems Unresolved:
1. check engine lite on--scan shows P0135
replaced with Ford upstream 02 sensor
lite persists
2. idle mostly rough; will die occasionally: surges
fuel pump checked OK
new fuel filters (2)
injectors surviced OK
vacuum leaks none
Additional Question:
Does O2 sensor P0135 problem cause idle, stalling problem?
Thanks for any help, suggestions (I read "related DTC discussions).
Nicolai
 Post subject: P0135 Mercury Tracer 1998 2.0 LS 124K miles
PostPosted: Fri Sep 07, 2012 3:15 pm
re above, wiring checked again for shorts: found water damage on wiring inside car near PCM; replaced PCM: runs better for 2 days but still shows P0135; checked Ford Dealer: "rarely does 02 sensor fail" and "you probably will have to replace wiring, none available here at parts" any suggestions? Nicolai
PostPosted: Fri Sep 07, 2012 4:05 pm
before you purchased the new FORD OEM o2 sensor.... did you check the heater portion of sensor for 12v- and check fuses?
Good thing you checked the fuel pressure - what was the pressure (psi) ?
PostPosted: Sat Sep 08, 2012 1:24 pm
Hello kev2, all fuses are OK; don't remember fuel pressure reading number but was up to par; the P0135 reading: FUEL SYSTEM 1=CL FUEL SYSTEM2=NA CALC LOAD (%)=33.7 ECT(F)=192 STFT BI(%)=-4.7 HAVE NOT CHECKED HEATER SENSOR FOR 12V. NICOLAI
PostPosted: Wed Oct 03, 2012 5:18 pm
To finish off...first of all, is this car of mine actually ...a female?!! Couldn't make up her (its) mind? Replaced the PCM. Then, the heater core blew out; by-passed the core; low and behold, the check engine light finally went out; the cooling fan wouldn't go on--then it did. (did the water short out the wires in the harness leading to PCM?) So now, with winter coming, $ for new core? Or new used car? Thanks for comments. N.
Users browsing this forum: AddThis.com Robot, Bing [Bot], Google Adsense [Bot], kev2, Yandex [Bot] and 26 guests
Powered by phpBB® Forum Software © phpBB Group
Actron CP9125
Actron CP9125 PocketScan Code Reader
Buy Now from Amazon.com
About Us - Contact Us - Links
Note: All information on this site is copyright © 2004-2012 OBD-Codes.com
