could be a temp sensor issue but still could be a coolant level issue, coolant strength, rad fan problem, etc. I've had lots of problems in the past with those codes using aftermarket parts so It might be worth verifying that the two thermostats openned at the same temp and that the install was in fact done properly
Users browsing this forum: Google [Bot], Google Adsense [Bot], MSN [Bot], Yahoo [Bot] and 6 guests
