Post subject: Problem with '02 Mitsubishi Mirage Stumble and stutter
Posted: Sun May 21, 2006 1:38 pm
The problem started back in December 05. The temp got so low that there was a danger of gas lines freezing and I didn't have much fuel in my tank. I went to the gas station that night and filled up my tank but I noticed some hesitation. The next morning I noticed more hesitation and got some water remover for the fuel lines. This seemed to help for a moment but the problem returned. Since then I've replaced the fuel filter, coil packs, spark plugs two times, both 02 sensors, the MAP sensor, and checked and cleaned the injectors. I backprobed the Throttle Position Sensor and it gave me the correct reading. Any suggestions? Please help.
how did you check/ clean the ful injectors? did you switch cyl#2 with another one, Is the resistance value the same for all of them, Have you done a compression test?
I removed the fuel rail and wiped the tips clean with some gas then switched #3 with #2 injector. Replaced everything and the engine idled smoother but when I test drove it, the code came back on cyl 2 again. Haven't checked compression yet. While I was under the car replacing the rear O2 sensor, I noticed the shield on the catalytic converter was a bit damaged too.
Plugs are only a few months old. I checked the compression and it looks good at 180psi
Is it true that since I disconnected the fuel rail I have to have the computer recalibrated before it will display new codes? I have a Code reader that gives me P0302 code and someone told me I needed to have the computer recalibrated before I can get the real problem code since I removed the fuel rail.
doubt it unless there was some kind of sensor on the fuel rail, recheck for a vaccum leak around the o-rings for the fuel injecors and the rest of the intake and check the connector at the misfiring injector with a noid light to be sure the pcm is pulsing it. When it's running is there a misfire you can feel?
The noid light shows the injector is pulsing. While running there is a stumble that feels like its misfiring. That plug (#2) is always more burned that the others upon removal. A slight bit of oil or dark fuel around the threads but not on the tip of the plug.
Is there a vaccum leak?, Sounds like an engine issue to me, sometimes compression tests don't reveal everything. do you know how to do a cylinder leakage test? so it isn't a coil on plug system? Nobody's done a timing belt or some other similar job to this car recntly have they?
I'm just wondering if the belt is slipped. Does it have an EGR valve because i have seen egr valves cause misfire dtcs? Maybe you have alot of carbon on the valves?
Post subject: Re: Problem with '02 Mitsubishi Mirage Stumble and stutter
Posted: Sat Aug 22, 2009 6:07 am
This problem was resolved. It happened a couple more times. Stumble and stutter with code indicating misfire on cylinder 2 tends to be a bad coil rubber boot. about $70 for the kit from Advance Auto. Pop the bad one off, put the new one on and "bamm" problem solved. It is triggered by running the car with a bad alternator. If the power goes to and the car shuts off, a surge of electricity burns out the coil boot.
Users browsing this forum: Google [Bot], Google Adsense [Bot], Yahoo [Bot] and 26 guests
