It is currently Fri Nov 20, 2009 10:18 pm
 Post subject: 1997 ford f150 CEL codes 136 & 141
PostPosted: Sat Oct 17, 2009 5:11 pm
Could someone please tell me what the fix for these 2 codes are, I was told to replace the O2 sensor on drivers side after the cat, I did this with a matching bosch O2 sensor and had the light reset, but it came back on....HELP PLEASE :? :? :? :? :?
 Post subject: Re: 1997 ford f150 CEL codes 136 & 141
PostPosted: Sat Oct 17, 2009 7:18 pm
Firstly be sure the side of the engine you worked on is correct, wouldn't be the first person to get it switched up, secondly Bosch 02's often do not work properly in domestics for some reason, I think the heaters within the 02's draw too much and in turn the circuit becomes complete with a new sensor but the duty cycle of the heater is still too high and in turn the pcm thinks the 02 is still bad. I'd check that you have in fact changed the correct sensor and then be sure no fuses are blown, even if they don't say 02 or oxygen check them and replace any that are blown. If all of this checks out okay then I'd go to the dealer and buy the correct sensor.
Users browsing this forum: Google Adsense [Bot], MSN [Bot] and 24 guests
