2004 Audi A4. No prior problems at all. Yesterday after work my light came on. Car has 76,000. Codes are
0171- system too lean, cylinder #1 denotes bank 1
explanation : low fuel pressure or volume
probable causes: faulty H02 sensor, vacuum leak, MAF
0300- random cylinder misfire
explanation : lean air/fuel ratio
prob causes: ign system misfire, fuel injector fault, mechanical condition
0301-0304- each cylinder misfires
explanation: vacuum leak on engine
prob causes: ign system fault, fuel inj fault, mechanical condition
If they give me an explanation of Vacuum leak does that mean there is definitely a leak? I don't believe ALL spark plugs or ALL coil packs are bad, think the misfires are caused by whatever set off 0171? What is the best way to check each prob cause - I can't afford to guess and replace both O2 sensors, and MAF, and whats the best way to find a vacuum leak if I can't hear it?
Thanks in advance
