It is currently Fri Nov 20, 2009 6:44 pm
 Post subject: cod p0102 for ford
PostPosted: Sun Aug 30, 2009 3:33 am
Ford Number P0102
Type Powertrain - Fuel and Air Metering - ISO/SAE Controlled
Description MAF Sensor Circuit Low Conditions
Cause DTC P0505 not set Engine running, then the PCM detected a MAF sensor signal of less than 0.23v Check for leaks at air outlet tube and for loose tube clamps
could you pls tell how can i fix it
 Post subject: Re: cod p0102 for ford
PostPosted: Mon Aug 31, 2009 6:06 am
Clean the MAF with Brake Kleen or Electronics Cleaner.
Also check for vacuum leaks and/or loose clamps at the snorkel.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 20 guests
