I received the following error code, P0130 -> O2 Sensor Circuit Malfunction (Bank 1, Sensor1). I have reset the code and I am waiting to see if it comes on again. If/when it does I will replace the o2 sensor. How can I go about testing the oxygen sensor to see if it is good or faulty? Is there any type of test I can perform before replacing either of the 02 sensors. This is for a 2002 Sunfire.
A scope is really the best way! you guys have to rememeber an 02 sensor has a heater element as well as the sensing circuit. Often times the 02 will still sense but it runs too cool with a failled heater element. Unless you understand diagnsotics and can competently read a wiring diagram and utilize a dvom you're best bet is to replace the 02 or take it to a competent technician. As well your sunfire or just about any 4 cyl inline engine using 2 02's the sensor 0ne bank one is the upstream. Like we suggested replace both the upstream and downstream at that age and mileage and source them from the gm dealer.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 11 guests
