It is currently Fri Nov 20, 2009 7:42 pm
 Post subject: P0420 and P0446 Codes
PostPosted: Sun Jul 26, 2009 9:35 am
Hi,
I have a Camry 2000 V6. I keep good care on this car. However, about a month ago a problem started to develop. Only when the car is warmed up. When driving with the RPM between 1200 and 2000 the car is sluggish and the RPM drops for a split second. After a day or so the check engine light came on. I reset the onboard computer and the light went off but the RPM problem was still there. So I took it to Toyota a week later. They ran their check and nothing came up. The RPM problem is still there and a week after it was at Toyota the check engine light came on again. So I checked the Codes P0420 and P0460. Are they related and if so what could be my problem? If I clear these codes the engine light will go off for a while but the RPM problem is still there. I need to find out what it is so I can fix it.
Thanks for your help.
 Post subject: Re: P0420 and P0446 Codes
PostPosted: Sun Jul 26, 2009 1:22 pm
Have you replaced the fuel filter?
PostPosted: Sun Jul 26, 2009 1:44 pm
Hi,
I forgot to add that I have replaced the fuel filter because I thought that might be the problem. And I have also replaced the spark plugs because I thought I might have had a bad plug.
Thanks for vewing this post.
PostPosted: Mon Jul 27, 2009 5:50 am
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
I think is a EGR Valve stuck partially open. Killing the combustion and cooling the exhaust gases.
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
Is the gas cap worn? I am wondering if the Evaporation problem is due to a worn out gas cap. That is an easy test. Check for a worn or loose vacuum hose, but that will give you a higher idle, you never know, but does not hurt to check.
Users browsing this forum: Google [Bot], MSN [Bot] and 33 guests
