Page 1 of 1
[ 4 posts ]
Author
Message
jwelch5792
Post subject: Code p0305 and p0171 on 1999 chevy malibu
Posted: Sat Jul 18, 2009 7:19 am
What cause a code p0305 and a p0171 on 1999 Chevy Malibu with a V6? I replaced the plugs and wires about a month ago. Thanks Jesse
Sponsored Links
Posted: Today
Mohawkmtrs
Post subject: Re: Code p0305 and p0171 on 1999 chevy malibu
Posted: Sun Jul 19, 2009 6:51 am
Joined: Sat Sep 09, 2006 4:26 pmPosts: 830Location: Tyendinaga Mohawk Territory, Ontario
Did the codes appear after the new plugs/wires were installed? What about new Dist. cap and rotor? Did you use quality parts? Check for vacuum leaks (including manifold gaskets) on Bank 1 (Driver's side). Also swap Cyl.#5 injector with another cylinder and see if the misfire code changes. Are you sure #5 plug is firing? Good luck and keep us posted.
jwelch5792
Posted: Sun Jul 19, 2009 10:57 am
The codes appeared about a few months after i replaced the plug and wires. I replaced the coil packs. I used quaitly plugs and wire. I am sure that plug #5 is firing. Could this be caused by a bad catalyic converter? I have a lot of water coming out of the tail pipe. Thanks for the info. Jesse
Mohawkmtrs
Posted: Mon Jul 20, 2009 6:38 am
It's possible the cat may be restricted, but I would first swap #5 injector with another cylinder and check for vacuum leaks. A plugged cat/exhaust system will not set a P0171.
Page 1 of 1
[ 4 posts ]
Users browsing this forum: Google Adsense [Bot] , MSN [Bot] and 29 guests
Note: All information on this site is copyright © 2004-2008 OBD-Codes.com The information contained on this site is presented as information only. We are not
responsible for any actions you take on your vehicle. If you have any doubt as to repairs on your vehicle,
please contact a qualified technician. If we used information from another source in creating an article, we
have given credit where credit is due.
