P0153,P1131,P0442 on my van, It runs smooth but would like to solve the issue, I have heard of changing the O2 sensor, cleaning the MAF, etc.....can you guys with more experience help me or guide me on what to do.
For the EVAP code (P0442), the cheapest possible fix is to replace the gas cap. However check EVAP hoses from the engine back to the gas tank for cracks, loose connections, etc.
Make sure you get the parts from the dealer as aftermarket parts (in this case) can be suspect.
Cleaning the MAF may not be a bad idea as well. It too likely has 12 years of dirt on it.
Thanks Mohawkmtrs, I replaced the 2- oxygen sensors, cleaned the MAF, also replaced the PCV valve, spark plugs, cleaned the injectors and air filter, to be honest the van rides with more power, I haven't reset the codes but I noticed that the engine light when off by itself and back on after 1 hour or so. I am gonna give a couple days to see is the computer adapts to the changes (what would you suggest?) and then reset the codes. The only thing I did not do was to clean/replace the gas cap.
Well I just checked and the 3 codes are gone, but its now showing P1151...dang always something. Any ideas maybe because I cleaned the injectors and did a Tune-up?
Users browsing this forum: acan, Google Adsense [Bot], Yahoo [Bot] and 15 guests
