It is currently Fri Nov 20, 2009 6:04 pm
 Post subject: Passing Emission Test P0136 P0161 P0401 P0402 P0304
PostPosted: Thu Apr 06, 2006 1:00 pm
I have a 1997 Crown Victoria and it has failed the test twice here in Illinois.I have put an EGR valve, 2 O2 sensors, spark plugs and wires, but I still have an O2 sensor Circuit Malfunction(Bank 1 sensor 2-PO136), O2 sensor heater Circuit (Bank 1 Sensor 2-PO141), O2 sensor Heater Circuit (Bank 2 Sensor 2-PO161),EGR Flow Insufficent detect-PO401), EGR flow Excessive Detected-PO402, Cylinder 4 and 5 misfired detected-PO304. How can I resolve this problem? I have spent $300 already.
James
PostPosted: Thu Apr 06, 2006 1:15 pm
look for a vacuum leak around the intake manifold, quite possible the manifold is blown causing the fuel mixture too be wrong throwing the o2 sesnors out, and I'd bet the dpfe is not flowing right, MAF cleanning and throttle body cleanning not bad idea either
good luck and keep me postted
Jeff
 Post subject: o2 heater circuits
PostPosted: Thu Apr 06, 2006 4:54 pm
Check that the O2 sensors are getting power and ground for the heater circuits, possible that the pcm heater driver is dead but I doubt it, Which side of the engine did you replace the O2 sensors on ? Did you replace the upstream and downstream?
Users browsing this forum: Google Adsense [Bot], MSN [Bot] and 29 guests
