Went on a short trip today (100 miles round trip) at about 60 miles per hour and car started missing at idle to the point it would almost die. Checked codes and found P0101, P0300, P0171, and P0174. Changed front four plugs (out of time to change all) and now only have P0174 after about 20 miles of driving. Any ideas?
Look at the rubber boot that attaches the intake to the throttle body. I am NOT talking about the air duct from the air filter. If you follow the intake from right to left you will see a rubber coupler then a metal spacer then the throttle body. This boot will split and will cause all you issues. Check it REAL good with carb cleaner with the engine running and see if it stumples.
Users browsing this forum: Google [Bot] and 10 guests
