I replaced the fuel filter, still no good. There is a little bit of a flutter out of the drivers side exhaust. So I decided to pull the plugs and inspect them. I found them all in good shape other than the cylinder 3 plug was wet with gas. I then decided to check the compression maybe thinking I had a burned valve. I checked both #1 and #3 cylinder so far and and had approx. 135-150psi out of both. I couldnt go any further due to the weather so Ill check the rest tomorrow. At this point Im aggrevated but its not something I can walk away from and go back to, this is my only mode of transportation at this point. I cant help but think that its really something simple but its just not hitting me yet. I had an O2 sensor code before after the intake gasket went bad which was for bank 2 sensor 2 but it went away, after I cleared the code yesterday I had a P0135 which is an O2 sensor code for bank one sensor 2. I was thinking maybe it was the O2 sensor but now since I got a different code, I'm not so sure. I had to send my PCM to Hypertech and they checked it and reflashed it and said it was fine so Im ruling that out. After I get the compression test done on the remaining cylinders, I should be close to narrowing it down.
thanx
