It is currently Fri Nov 20, 2009 11:45 pm
 Post subject: 1996 Ford contour P0174 System to lean bank 2
PostPosted: Fri Mar 27, 2009 9:56 pm
I have a 96 ford contour V-6 2.5L i just tuned it up after the code P0174 P0171 came up i erased the codes after tuning it up Drove it around the block & the chck eng lite came back on with code P0174System too lean bank 2 any help would be appreciated.I heard you can clean the mass air flow sensor would this help???
STFT B1 % 14.06
LTFT B1 % 21.88
STFT B2 % 17.97
LTFT B2 % 25.00
Calc Load % 28.63
Eng RPM 717
Fuel Sys 1 CL
ECT(C) 75
 Post subject: Re: 1996 Ford contour P0174 System to lean bank 2
PostPosted: Sat Mar 28, 2009 7:48 am
Yes, cleaning the MAF with electronics cleaner may help.
Also, check for vacuum leaks, particularly on the PCV system and its hoses. There is an elbow down near the throttle body that goes bad.
It's hard to find it and check because of its location.
Good luck and keep us posted.
PostPosted: Sat Mar 28, 2009 8:47 am
with those numbers it a matter of time when the p0171 will come back to. You can try to clean the maf, but you need to check for vacuum leaks.
PostPosted: Sat Mar 28, 2009 10:27 am
Thanks for the info can i vacuum check the old school way with some carb cleaner or do i have to get a smoke check done??? I am on a budget trying to keep my cost down. I changed the PCV Valve the new one wasnt real tight going in & how would i get the factory clamp off its one of those one peice banded type?? and hard to get at. plus when i took the old one out the metal tube the rubber elbow was attached to moved a little anything to worry about?? I will let you Know if all of this helps Thanks again
PostPosted: Sun Mar 29, 2009 6:58 pm
that is usually where they leak..you can use carb. cleaner just be carefull.
PostPosted: Mon Mar 30, 2009 11:24 am
I found the leak was tube the PCV Valve sits in & the ribbed plastic hose from the PCV Valve to the filter housing on the firewall the plastic tube cracked where it connects to the Tee at the rubber hose to the PCV Valve Cleaned the MAF & Vacuum leaks all good now. Thank you for all your help I appreciate it :D
PostPosted: Tue Mar 31, 2009 6:22 am
We're glad you got it fixed.
Users browsing this forum: Google [Bot], Yahoo [Bot] and 18 guests
