Post subject: 2001 Dodge Ram P0132, P0135,P0138,P0141
Posted: Sun Feb 15, 2009 6:51 pm
Joined: Sun Feb 15, 2009 5:44 pm Posts: 1 Location: Perry Twp Ohio
I need help. I've replace both Oxygen sensor on my 2001 dodge ram 5.2 liter. I've reset the computer a few times. But I'm still getting P0132,P0135,P0138, and P0141. I've replaced the wiring harness but still have the same codes. I'm thinking it's a wiring problem. Because I'm getting no volts from the heating wires. Where does the wire run? I can not find a digram in any books and no luck on-line. Help. Please.
Post subject: Re: 2001 Dodge Ram P0132, P0135,P0138,P0141
Posted: Fri Mar 20, 2009 8:31 pm
You can check the HAYNES manual ( Buy on Advance autopart store or other store) for this car and look the electric diagram. There are the wires color codes and the numbers on the PCM connector that you can identify the wires of the each O2S.
Users browsing this forum: Google Adsense [Bot], MSN [Bot], Yahoo [Bot] and 27 guests
