The smell is Hydrogen Sulfide, as an educated guess, your Catalytic is going bad. You can get random misfires, EGR Codes, or Cat not reaching operating temps along with rough idle loose of power, slight over temp like 220 F or so, no acceleration and many other issues with plugged up Converters, sometimes not even a code!
I am guessing that you have the 3.4 V6 on it.
I heard several ways to test it, take the O2 Sensor off and start the car so gases can escape and reduce the back pressure, other is to drill a hole before the Cat and if that not is the issue, place a Self Tapping screw to plug it up. Another is replace the Cat but that could be expensive, like $65 to $200 depending which one you buy plus labor if a muffler shop does it. For an old car I recommend the $65 that all you need to do is cut the old one and weld the new one so you need some to weld with, the other, you need to unbolt the Cat and you can shear a nut or stud at the manifold and you are going to have a world of trouble for that.
Now, Cats does not fail easy, excess oil, fuel and Glycol can destroy a Cat. On these cars they have the bad tendency to have Lower Intake Manifold gasket leaks, that means, that some Glycol can get to the intake manifold and get sucked in the combustion chamber and hinder the combustion on one cylinder. the water galleries are on the corners of the Manifold, the 5th Cylinder is the last one on the bank. If Glycol gets there even in small amounts, little by little will plug the Cat.
There is class action suit on leaking LIM Gaskets, so you might get a refund on the repairs. Call few dealers about it.
Now you have 2 issues to investigate... good luck !
