Post subject: 2000 Ford Focus Codes: p0136,p0141,p0171
Posted: Wed Feb 11, 2009 3:53 pm
At first I had only codes 141 and 171. I had the spark plugs, wires and one of the o2 sensors replaced. After I got my car tested again, those same codes plus 136 came up. So now I don't know what to do.
Should I change my other o2 sensor? or is it something different?
Post subject: Re: 2000 Ford Focus Codes: p0136,p0141,p0171
Posted: Sat Feb 21, 2009 2:00 pm
I currently have a po171 code on my 00 Ford Focus Se. I changed the fuel filter, both o2 sensors, the spark plug wires and plugs. I want to change the pcv valve prior to resetting the code. Do you know where its at? I thought it was on the valve cover. I followed the line from the air filter box to the valve cover, but it doesn't look there is anything that I can remove on there. Any help would be greatly appricated. I bought a new pcv valve, but not sure what to do with it.
Users browsing this forum: Google [Bot], Google Adsense [Bot], Yahoo [Bot] and 35 guests
