It is currently Sat Nov 21, 2009 12:04 am
 Post subject: 2002 code p0306
PostPosted: Sun Feb 08, 2009 7:50 am
i replaced spark plugs gas filter #6 ignition coil #6 injector compression is good on all cylinders. # 6 cyl has injector pulse and spark. vacumme steady at 18" yet #6 cylinder seems to be totally dead . the only thing i can think is maybe intake gasket or manifold cracked , but cant see underside of intake. has anybody seen simular problem? id like to find out before i remove intake
 Post subject: Re: 2002 code p0306
PostPosted: Sun Feb 08, 2009 5:09 pm
What vehicle? Just because you have injector pulse doesn't mean that the injector is okay. Did you perform fuel injector leakdown test? It's imperative to check for a clogged injector before condemning anything. How did you test for injector pulse? Did you provide a ground or use the injector driver ground?
PostPosted: Mon Feb 09, 2009 6:55 am
2002 chevy tahoe 5.3 flex fuel code z i swapped coils,injectors,wires #6 cyl still is dead it has same compression as all the other cylinders
PostPosted: Mon Feb 09, 2009 8:02 am
ok i found the problem i took off the valve cover the exaust valve spring was broken on that cylinder iguess it holds valve closed enough for a good compression test but not when its running :D
Users browsing this forum: Google Adsense [Bot] and 15 guests
